AutoCAD Forum
Adding Drawing Block as Plot Stamp
2 REPLIES 2
1430 Views, 2 Replies
How can I add my drawing block as plot stamp?
Example [FOR INFORMATION ONLY] in the format in attached image.
Tags (1)
2 REPLIES 2
imadHabash
HI,
you may try from PLOT dialog .
Imad Habash
pendean
PLOTSTAMP command only does text (predefined parameters and FIELDs too). Look it up in the program and in HELP.
IMAGEATTACH command is or attaching images if you want to do that, place it on a unique layer you toggle on/off when you need it.
HTH
AutoCAD Inside the Factory
