AutoCAD Forum
Adding block on every sheet in a sheetset
3 REPLIES 3
458 Views, 3 Replies
I have a sheet set containing hundreds of sheets. I want to add the same image block to every page of it. Are there any easy way to do that instead of open the sheet one by one? Thanks
3 REPLIES 3
john.vellek
Hi @Anonymous,
Do your sheets share a common Xref such as a titleblock? If so, you could add that block to the shared file and then it should be available in all the sheets.
If you don't have a shared sheet, you might consider running a script to insert the block.  ScriptPro might be one option to do this.
John Vellek
JTBWorld
A batch script app like ours SmartPurger or JTB CAD Automation Tools can do this or we have a custom solution that can easily be modified by us for this specific purpose.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Jimmy's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Forma Design Contest
AutoCAD Beta
