Where is the standard menu location for the main menu in Acad 19?
I had a guy customizing his menu, loading a new menu. His main menu is now gone. I need to reload the main menu.
Solved by john.vellek. Go to Solution.
Hi @mralley612,
Mine is located here:
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2019\R23.0\enu\Support
Hi @mralley612,
I cant find the "AppData" file
Hi @mralley612,
Yes, that folder is normally hidden. In Windows Explorer, you can select the View Tab and then Hidden Items.
Hi @mralley612,
