AutoCAD Forum
Acad19 menu location
4 REPLIES 4
mralley612
1855 Views, 4 Replies
Where is the standard menu location for the main menu in Acad 19?
I had a guy customizing his menu, loading a new menu.  His main menu is now gone.  I need to reload the main menu.
4 REPLIES 4
john.vellek
in reply to: mralley612
Hi @mralley612,
Mine is located here:
C:\Users\vellekj\AppData\Roaming\Autodesk\AutoCAD 2019\R23.0\enu\Support
John Vellek
mralley612
in reply to: john.vellek
I cant find the "AppData" file
pendean
appdata file?
john.vellek
Hi @mralley612,
Yes, that folder is normally hidden. In Windows Explorer, you can select the View Tab and then Hidden Items.
John Vellek
AutoCAD Inside the Factory
