I found out about SP2 for AutoCAD 2013, so I downloaded it. It doesn't want to install. I get the error message: "The service pack could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct service pack for the product."
I have Design Suite 2013 installed on 2 machines, & I get this message on both workstations. Any thoughts?
I changed the default program to acad.exe. I receive the same error message. Thanks for taking the time to help.
MECH 2013 SP2 is here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21818160&linkID=9240898
Plain AutoCAD 2013's SP2 is the completely wrong update to get. You are NOT using AutoCAD, you are running MECH "as AutoCAD".
See the other topic around here called "catch 22" for the same exact discussion. Good luck.
They worked. Thanks for the help. It looks like it may have fixed my issue with a conflict concerning the 3dconnexion space navigator too.
