01:21 PM
I found out about SP2 for AutoCAD 2013, so I downloaded it. It doesn't want to install. I get the error message: "The service pack could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct service pack for the product."
I have Design Suite 2013 installed on 2 machines, & I get this message on both workstations. Any thoughts?
Link copied
