AutoCAD Forum
A way to change paperspace scale in the model space.
5 REPLIES 5
unggansu2
550 Views, 5 Replies
Good morning, good sir.
I was wondering whether there is a way to change the viewport's scale in the paperspace, without actually entering the paperspace, i.e. changing it inside the model space (be it through built-in features or a LISP routine). It could really helps me in the long run.
5 REPLIES 5
Patchy
in reply to: unggansu2
Click on the viewport frame, change the scale in Properties Pallet
Not requiring entering the papers space.
unggansu2
in reply to: Patchy
Hello, thank you for your kind response.
I see, that is indeed a way to do it that I'm unaware of. Is there also a way to change the viewport scale without entering the layout tab at all?
If possible, I wanted to set everything up in the model space, or at least the viewport scale. My device gets very laggy or even freezes when I switched tab due to gargantuan amount of objects I had. (I cannot include the file sadly, due to NDA issue)
paullimapa
You are welcome to download my free VpScale Apps which includes a command called DDSetVpSc.lsp
Though the DDSetVpSc.lsp still requires to go into each layout you've selected to change the VPort's scale, at least it'll do everything automatically.
Paul Li
IT Specialist
@The Office
unggansu2
in reply to: paullimapa
Good afternoon.
Thank you for your kind response. It is indeed what I was looking for, even if it still requires to navigate into each layouts. This would really helps shorten (or hopefully remove, even) the time consumed manually adjusting the scales.
I will give it a shot, it will do for now.
Tags (1)
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Forma Design Contest
