AutoCAD Forum
3D printingtroubles
10 REPLIES 10
Message 1 of 11
530 Views, 10 Replies
3D printingtroubles
I am having
Spoiler
problems this morning trying to print in 3D. when I send to print service under the output tab, i am asked to select the object. When I right click on the object then left click to enter, it asks me to select object again. It is as if the object isnt recognized asa 3d object. How do I make it a witertight mesh like it asks for. I made the object using the extrude command. Not sure where to turn.
Spoiler
Thanks.
10 REPLIES 10
Message 2 of 11
@Anonymous wrote:
I am having
Spoiler
Spoiler
Thanks.
You should be left clicking to select, then right click to enter.
Message 3 of 11
Ok. I am directionally challenged. I am left clicking on the object then right clicking to accept. That part I am doing correctly. I just stated the wrong way. Message says no watertight meshes selected.
My apology for the confusion.
Bryan
Sent from my iPad
Message 4 of 11
JDMather
Do you have a solid body?
Does List or Properties return 3D Solid?
Can you attach the dwg file here?
Message 5 of 11
in reply to: JDMather
I teach high school and am just about 5 minutes ahead or 5 minutes behind
my students. I ahve attached the drawing and maybe you cantell me what
needs to be done. I have tried to join the parts but this does not help.
Any advise is appreciated.
Bryan Bates
*Industrial Technology Instructor*
*Conway Springs High School*
*620-456-2963*
Message 6 of 11
JDMather
I do not see attachment.
Are you replying from a phone or from a web browser?
What is the size of the file?
If it is too large to attach here - right click on the file name and select Send to Compressed (zipped) folder.
Attach the resulting *.zip file here.
If it is still to large to attach here - post back for instructions on using A360 drive to host the file.
Message 7 of 11
Try This attachment.
Thank You,
B Bates
Message 8 of 11
JDMather
Propterties indicates that you have Region and several Surfaces.
You must have a solid to create an stl file for 3D printing.
Run the surfsculpt command and select all to get a solid for exporting.
Message 9 of 11
Thank You,
B Bates
There are no solids in that file, lots of surfaces though.
Message 10 of 11
Thank You. That did it. Now my question is why did only some drawings turn out like that whily others did not.
Sent from my iPad
Message 11 of 11
JDMather
An understanding of Surface Modeling vs Solid Modeling is required.
You might start with the AU presentations linked here
http://home.pct.edu/~jmather/content/CAD238/AutoCAD_2007_Tutorials.htm
unfortunately the information is a little old as I seldom use AutoCAD anymore.
If you do a lot of mechanical type work - I recommend that you look into Fusion 360 or Autodesk Inventor.
AutoCAD Inside the Factory
