AutoCAD Forum
3d hatch to paper viewport
11 REPLIES 11
Message 1 of 12
Solar-emc
658 Views, 11 Replies
Solar-emc
In autocad 2018, I made a model in 3d modeling section, extracted the edges, added hatching. Back to Paper, add a viewport to show the 3d model. But the hatch doesn't show in Paper mode. Is this possible, thanks
Tags (2)
11 REPLIES 11
Message 2 of 12
pendean
in reply to: Solar-emc
pendean
Community Legend
Community Legend
What is SHADEMODE set to inside your layout viewport?
Message 3 of 12
Solar-emc
Solar-emc
In 3d Modeling, Under the Visualizer tab it's set to Wireframe
In Paper mode I can't find a shading mode.
 thanks
 thanks
Message 4 of 12
pendean
pendean
Community Legend
Community Legend
Post your DWG file please.
Message 5 of 12
Solar-emc
in reply to: pendean
Solar-emc
Sorry, My company will not allow the files out of house.
Where do I find Shading?
Message 6 of 12
pendean
pendean
Community Legend
Community Legend
Understood: can you WBLOCK out just that portion then share it here?
Message 7 of 12
jayhar
jayhar
You wrote
<<<<In Paper mode I can't find a shading mode.>>> its inside your layout viewport. double click in viweport, MSPACE will active & command "SHADEMODE" (Attach 1).
1. Set Shademode= 2dwireframe
2. Turn OFF GRAPHICSCONFIG
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Thanks You
Jayhar.M.J
Message 8 of 12
Solar-emc
in reply to: jayhar
Solar-emc
Tried to follow your directions and could not follow past SHADEMODE. Oh well thanks for trying to help me.
NO this is not resolved so I can't mark it, So were is the UN-solved button?
Message 9 of 12
pendean
pendean
Community Legend
Community Legend
You double-click inside the viewport.
You type SHADEMODE then hit <enter> on the keyboard to activate the command
Now you can make the changes suggested in post #7
FWIW If there is no "solved" tag, it is unsolved by default. That's how the forum posts work.
Message 10 of 12
ChrisPreece
ChrisPreece
Hi @Solar-emc,
I'm just checking in to see if you need more help with this. Did the suggestions that @jayhar and @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
Hi @Solar-emc,
Chris Preece
Message 11 of 12
Solar-emc
in reply to: ChrisPreece
Solar-emc
no never got a solution
Message 12 of 12
pendean
pendean
Community Legend
Community Legend
Did you try what was noted in post #9 then post #7 yet?
AutoCAD Inside the Factory
