In autocad 2018, I made a model in 3d modeling section, extracted the edges, added hatching. Back to Paper, add a viewport to show the 3d model. But the hatch doesn't show in Paper mode. Is this possible, thanks
In 3d Modeling, Under the Visualizer tab it's set to Wireframe
In Paper mode I can't find a shading mode.
thanks
You wrote
<<<<In Paper mode I can't find a shading mode.>>> its inside your layout viewport. double click in viweport, MSPACE will active & command "SHADEMODE" (Attach 1).
1. Set Shademode= 2dwireframe
2. Turn OFF GRAPHICSCONFIG
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Tried to follow your directions and could not follow past SHADEMODE. Oh well thanks for trying to help me.
NO this is not resolved so I can't mark it, So were is the UN-solved button?
Hi @Solar-emc,
I'm just checking in to see if you need more help with this. Did the suggestions that @jayhar and @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
