2019.1.2: osnap don't pick exactly where I want
pproestos
Message 1 of 53
pproestos
I have installed Autocad 2019 with the latest update 1.2.
I create some polylines and then with only endpoint snap I try
to pick the end of a line and draw a new line.
If I do this a little quicker, it picks a little further from where I want.
Why this?
Should I reistall everything?
Please a little help.
thx.
Replies (52)
Message 2 of 53
Alfred.NESWADBA
by any chance, do you have "Object Snap Tracking" (<F11>) active on your object snap settings?
If yes please disable it and try the object snap behavior again.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 53
pproestos
Thx for the answer Alfred,
No, I have it already disabled.
Still I am having this problem...
Message 4 of 53
cadffm
UCS
world
PLAN
world
REGEN
Still?
Which coordinate position is your endpoint?
LUPREC 8
command: ID
Sebastian
Message 5 of 53
pproestos
Tried it.
Endpoint position  X = 8.18756603E+05     Y = 2.30698288E+06     Z = 0.00000000
If I try quickly/repeatedly 10 times to pick the end point
of a line, 9 times it pick it up precisely and 1 time
it picks a little further...
Message 6 of 53
cadffm
The gap is very small, but at  plan=wcs, position WCS 8,2 that should not happen.
Delete all, except ONE line. Create a new (red) one with end-snap and share this dwg with us.
Sebastian
Message 7 of 53
designdistrict7
I am not sure , But try ''Flatten'' command . Enter command and select all line and enter, then try to pick
Message 8 of 53
pproestos
No it isn't flatten.
Here is the dwg.
I try to pick the end of the red line and draw the
green line.
If I do this very quickly about ten times.
There is one time that picks where you see the green line...
Message 9 of 53
RobDraw
The apperture setting should help:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Rob
Message 10 of 53
cadffm
"If I do this very quickly about ten times. There is one time that picks where you see the green line..."
I would say this time the object snap was not used and the starting point corresponds to your cursor position.
If I make sure the object snap is used (I see the symbol of the object snap END) then it has delivered the correct result with now 50x.
Increase apperture or work more precisely with the mouse, I can not think of more.
And if you create architecture, then you better work closer to zero (in general).
Sorry.
Sebastian
Message 11 of 53
pproestos
Οk first of all thanks everybody for the support, because
in this situation I needed to hear various opinions from experts, before
attempting reinstalling everything, wich I did and now everything works well.
Apologize for the confusion, but I think I got crazy my Autocad... 🙂
I forgot to say that in the Help->About it was written "Autocad 2017" !!!!!!
I think that instead to transfer my previous workspace with cui command,
I copied my old .cuix file and overwrite Autocad 2019's one and Autocad
began to have strange behavior.
I think that maybe it was this the cause....
I don't know exactly, this what I suppose.
Anyway now after a clean reinstallation, now it works normally.
Thanks again.
Cheers.
Petros.
Message 12 of 53
Alfred.NESWADBA
Definitely not a good idea, but thank you for reporting this as this can be an important information for future readers too!
- alfred -
Alfred NESWADBA
Message 13 of 53
pproestos
going back to my problem...still the same 🙂 🙂
Maybe my file is corrupted, maybe my Autocad is corrupted or my Windows....
Anyway I roll back to Autocad 2018 and see if there,
I have the same problem...
Message 14 of 53
Alfred.NESWADBA
so you had the problem solved and it now reappeared?
Have you logged out in the meantime or did your workstation go to sleep-mode?
Are you having any tools like registry cleaners running automatically?
- alfred -
Alfred NESWADBA
Message 15 of 53
pproestos
Alfred thx for answer me. I appreciate that.
I have installed 2018 to see if that happens also there.
I am going to do some tests and be back.
Maybe I pick too quickly the end point and loose
precision as cadffm said...
But that's strange because I have 28 years of using Autocad!...
Message 16 of 53
pproestos
Ok @Alfred.NESWADBA and @cadffm
I figured out what is this.
It's not an osnap problem, but a "graphics" problem.
I join two different polylines and I attach three images.
with three levels of zooming.
As you see my ucs icon appears very strange and also
the polylines appear apart, like I didn't join them into one line.
Can you tell me if this is problem of my graphics card?
Same happen to Autocad 2018...
More zoom:
and more zoom again: (ucs icon dissapear!!!!!!)
Message 17 of 53
pproestos
Message 18 of 53
cadffm
It's right and "normal", not a problem with you graphic card.
It is (only) a bit dependet of your graphic settings.
Sebastian
Message 19 of 53
Alfred.NESWADBA
This only happens when you have an active hardware acceleration, I guess. Am I correct that when disabling hw-acc (command _GRAPHICSCONFIG) the UCS icon looks normal?
- alfred -
Alfred NESWADBA
Message 20 of 53
pproestos
yes... well never mind...
I got back to 2018 for the moment and
I will do some tests to see if have a real osnap problem or
this is my impression...
cheers from Athens.
Petros.
