AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
When using presspull the cursor wont stay still
2 REPLIES 2
247 Views, 2 Replies
I am using a 2016 macbook pro. When I go to click on an  object with Presspull the cursor starts going crazy and wont stand still for me to click on the object. It only happens when I use the presspull tool. How can I fix this??
2 REPLIES 2
maxim_k
Welcome to Autodesk Forums!
If you are trying to use PRESSPULL in the drawing which have a lot of geometry, than it us better to isolate only those objects you want to presspull.
If you have a lot of splines in the drawing, than it is better to convert them to Polylines.
PRESSPULL works well in the simple drawings, in complex drawings I prefer to use EXTRUDE command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
