hello!
Thanks for your concern and keeping us updated.
The earlier suggestion was to give a DWFattach command, but in AutoCad 2015 the command is not in the system. Only DWFframe and DWFosnap.
Please advise further.
Hi @einunshamss,
Open your External Reference manager (XR) and at the top left corner, drop down the menu and select Attach DWF.
I'm not sure what is wrong but when the file selection window pops up, it doesn't have .dwf option and resisting to upload my .dwf
Thank you in advance.
HI @einunshamss,
Thanks for the screenshot. It appears that you are in AutoCAD for Mac which does not have this feature.
If you want to attach your file I can print it to a PDF for you if you like.
Did you want to add your file to the thread so that John can help out further ?
Did any of the posts in the thread help with the issue? Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
