AutoCAD for Mac Forum
Welcome to Autodeskā€™s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
When using presspull the cursor wont stay still
2 REPLIES 2
315 Views, 2 Replies
I am using a 2016 macbook pro. When I go to click on an  object with Presspull the cursor starts going crazy and wont stand still for me to click on the object. It only happens when I use the presspull tool. How can I fix this??
2 REPLIES 2
maxim_k
Welcome to Autodesk Forums!
If you are trying to use PRESSPULL in the drawing which have a lot of geometry, than it us better to isolate only those objects you want to presspull.
If you have a lot of splines in the drawing, than it is better to convert them to Polylines.
PRESSPULL works well in the simple drawings, in complex drawings I prefer to use EXTRUDE command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those postā€™s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
