Hi i want to buy new imac with m3 chip for using autocad LT but i am confused as to buy which model because the standard models come with 10 core 10 gpu and 8gb ram which are readily available but if configure it to 16 gb it takes 2-3 months . Should i go with whats available which is 10core 8gb or should i configure it to 16gb and wait.
Solved by pendean. Go to Solution.
Hi @arshbrady ,
Anyway, 16 Gb is always better then 8 Gb.
Keep in mind that GPU on Silicon Macs uses shared memory.
