Extracting XYZ coordinates from survey information
jennifermacleay1
jennifermacleay1
I asked yesterday regarding extracting the XYZ info and someone had done this for me which was appreciated!
Although, I don't think all levels spots were accounted for?
Could someone extract this information for me? Much appreciated!
maxim_k
Hi @jennifermacleay1 ,
It was me.
I exported points once again. There are 4931 points in your drawing. Is this correct?
Look at the file in the attachment.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jennifermacleay1
Ah, apologies. I think the issue is on my end - I need to format the text so it's not in columns and rows. Do you know a fast way of doing this?
So it reads as below for example - [tab] is where a tab space needs to be entered.
360000.00[tab]360000.00[tab]360000.00
Thank you for your help!
maxim_k
If you need TAB as separator instead of comma, you can use attached LISP (PTEXPORT command after you APPLOAD it).
I also attached the result.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jennifermacleay1
Maxim - thank you so much for your help.
Could I ask you to extract the XYZ from the attached file? [I've removed the levels text shown in the previous DWG as they have xyz coordinates set to them which need omitting to allow only the spot levels to be extracted].
Sorry for all the back and forth and thank you again!
jennifermacleay1
Maxim, thank you for this.... I seem to have replied to myself!
maxim_k
Could I ask you to extract the XYZ from the attached file? ....
Here it is.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
