AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Return key not longer works in Autocad 2024 for Mac
6 REPLIES 6
betazero
462 Views, 6 Replies
Huh? You have to hit space or the command just fails if you hit return....Is there a setting for this? Geez...took me a while to figure out what the heck was going on....
Russell
6 REPLIES 6
maxim_k
in reply to: betazero
Hi Russel,
I don't see this problem on my side.
What keyboard are you using?
Which Return key do you mean? Is it return key on main keyboard or on the numeric keyboard?
Please clarify - what do you mean by "command fails"?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Your not the first 2024 user to report this: not sure there is a quick fix without knowing more about your setup, OS version, keyboard/mouse etc. OR roll back to 2023 until a patch is provided for 2024.
betazero
in reply to: pendean
Also, spacebar while writing text does not add a space....It is the Apple Magic Keyboard. The spacebar obviously works since I can hit enter for commands ( and write this message) also return works too.
This is a pretty nuts problem to have. I have to copy a space and past it in order to add a space while typing mtext...
edit - This is by the way the normal return key
edit - So Shift+space adds a space...What the.......Also return works normal inside mtext.
edit - Also Shift+return works as return......Uh...wierd stuff
maxim_k
@betazero ,
Looks like something is wrong in the interaction between AutoCAD and your current keyboard.
What macOS do you have on your Mac?
Have you tried different keyboard?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Hi @betazero ,
I think I figured out the root of your problem.
It is related to custom shortcuts you created with CUI command.
The solution is >>>>here<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
betazero
in reply to: maxim_k
Maxim to the rescue again.
Thank you,
Russell
