AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Random lines in transparent hatch when exporting to pdf
4 REPLIES 4
923 Views, 4 Replies
I'm working with Autocad 2016 on Mac and there are random diagonal lines on all the hatches that have transparency when I print to PDF.
How do I fix this?
Thanks for your help.
Tags (1)
Labels (5)
4 REPLIES 4
imadHabash
i suggest to follow this AKN article that may help . >> Click <<
Imad Habash
in reply to: imadHabash
The problem isn't fixed.
I put the HPMAXLINES to 1000000. I am not sure about the GRAPHICSCONFIG, there is no ''basic mode'' option. The options are acceleration/degradation/general options...
I tried to export the same drawing from a PC using DWG to PDF.pc3 and it works fine. Maybe the problem is with the plotter on Mac?(There is no DWG to PDF.pc3 on Mac, isn't it?)
Thank you,
maxim_k
Hi @Anonymous
Yes, there is such defect (bug) in AutoCAD 2016 for Mac.
Please try this workaround:
https://macacad.wordpress.com/2013/04/03/workaround-for-printing-solid-hatches-with-transparency-in-autocad-for-mac/
BTW, since 2019 version AutoCAD for Mac uses the same PDF engine as AutoCAD for Windows and there is no such issue in AutoCAD 2019, 2020 and 2021.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
The workaround worked out! Thank you very much 🙂
