Just started to use AutoCAD again after a 25 year hiatus (left architecture for the internet), and have run into a problem I can't seem to solve.
I created a drawing with a bunch of layers, for text, glazing, dimensions, etc - but when I go to print, only the default layer 0 does so.
To get it done, I moved all my elements to layer 0, but of course this isn't the way to do it!
I have included a copy of my drawing if someone would be so kind to tell me where I have missed this property or something?
Solved by maxim_k. Go to Solution.
Welcome to Autodesk Forums!
Hi @Anonymous ,
All layers in your drawing, except layer 0, have "Not to plot" property enabled.
You need to turn off this option.
You can set Plot option for layers with Layers palette, but this option is not visible in Layers palette by default, so you need to make it visible at first. Right-click on the layers table caption:
Now click on Not Plot icon for each layer.
NOTE: Defpoints layer is AutoCAD service layer which never plotted.
