Announcements
Help with dividing a drawing in two
Good morning,
My firm is working on a project and I need to divide an Autocad drawing into two pieces in order to move it into another software for rendering. (The software does not allow such a large file, the project is 24 acres)
I have looked and I can't seem to find a way or a command that would help me do so. I am at a standstill. Divide command will not allow me to choose more than one object at a time. I am currently using 2019 mac.
Please advice.
Thank you in advance!!
imadHabash
DIVIDE command is NOT the command that will help , it's totally another story !!
Since we don't have any image for your drawing , the idea is to look and search for an area that you can separate from .
all waht you have to do is to use WBLOCK  command or  SAVE AS command ( recommended ) . now you have two dwg files , remove one part from each .
Don't forget to use AUDIT , -Purge ( Regapps ) and Purge commands for both files to clean your CAD dwg and reduce file sizes .
Imad Habash
pendean
Community Legend
Community Legend
You create two DWG files with SAVEAS command.
ERASE one half of your content in one file.
ERASE the opposite half of your content in the second drawing.
What else would you like to do?
Thank you for your suggestion.
I am currently trying to make a section a WBLOCK.  However, I have two long lines running down the plan. Would there be a way to do a clean cut through the middle? Like a clean horizontal line? I'd like to cut where the light blue line is in the middle.
Attached is the screenshot of the project.
Thank you!!
I tried your suggestion and I simply copied half on the drawing and then added a reference line going across and lined up the verticle lines with that. It worked just like I needed.
The WBLOCK suggestion would have worked too. I managed to get it to separate with the reference line as a guide.
Thank you!!!!!
