AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Making a grayscale pdf from Autocad 2012 for Mac
13 REPLIES 13
Message 1 of 14
1509 Views, 13 Replies
I am trying to create a grayscale pdf from layouts in my Autocad file. I'm using Autocad 2013 on OSX 10.9.2
So far I have tried using pagesetup for each layout, chosing monochorme.stb in the Plot Style Table. The box for "print with plot styles" is checked. When I chose "save as pdf" or "open pdf with preview" in the lower left corner, I do get a pdf, but it is not grayscale and is of low quality.
I have read over threads related to this issue and still haven't found a solution.
page setupresulting pdf
Tags (3)
13 REPLIES 13
Message 2 of 14
maxim_k
Welcome to Autodesk Forums!
What visual style do you have in viewports?
You can print in grayscale only with 2D Wireframe visual style.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 14
in reply to: maxim_k
Hi Maxim. Everything is in a 2D Wireframe visual style.
Message 4 of 14
maxim_k
Activate viewport and in Properties palette check Shade plot option, it should be "As displayed".
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 14
The properties pallette for the viewport in the properties inspector indicates the shade plot is "as displayed" The problem persists.
Message 6 of 14
maxim_k
Do you use True Color for Layers (objects) in your drawing?
Have you tried to plot another file with this plot style table file? It is possible that plot style table file is corrupted.
Can you post your DWG file here (along with plot style table and Xrefs (if any)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 14
maxim_k
Try to compress CTB file (right click on it and select Compress), then attach resulting ZIP file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 14
Thanks Maxim
Message 9 of 14
maxim_k
OK, I'll look at your file today, little bit later, for the moment I'm far from my Mac.
M
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 14
No prblem. I really appreciate your help.
Message 11 of 14
maxim_k
Here are the instructions:
- activate Model space
- open Properties Inspector, ensure that nothing selected, on "Current Properties" tab find Plot Style section, then Plot Style Table
- open drop-down list and select monochrome.stb
-  switch to Layer Properties tab in Properties Inspector and find "Plot style"
- select "Style 1" from list (instead of "Normal"
- at the command prompt type -LAYER (with hyphen before command name) then hit Return, than type PS and hit Return, then type Style 1 and hit Return, then type * (asterisk) an hit Return twice:
Command: -LAYER                         <- Hit Return here
Current layer:  "Dimensions"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: PS                    <- Hit Return here
Enter Plot Style Name or [?] <Style 1>: Style 1                       <- Hit Return here
Enter name list of layer(s) for plot style name Style 1 <Dimensions>: *               <- Hit Return here
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:                         <- Hit Return here
Now go back to the Layout and try to plot.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 14
Thank you Maxim. That worked for me!
Message 13 of 14
risha_chitalia
i want the stb for grayscale could you please send it
Message 14 of 14
maxim_k
in reply to: risha_chitalia
Hi @risha_chitalia ,
You can create Grayscale STB Plot Style table file yourself:
- open monochrome.stb file in Plot Style Table Editor, use "Save as" button to save it under another name, for example - Grayscale.stb
- select "Style 1" Plot Style on the left, change Color to "Use object color" and check-mark "Grayscale" option
- pick on "Save & Close" button
 - assign this new "Grayscale.stb" to the Layout you want to print
- change "Plot Style" property of all Layers in the drawing to "Style 1"
- print your drawing:
Just in case I have attached an archive with ready for use "Grayscale.stb" file
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
