I am trying to create a grayscale pdf from layouts in my Autocad file. I'm using Autocad 2013 on OSX 10.9.2
So far I have tried using pagesetup for each layout, chosing monochorme.stb in the Plot Style Table. The box for "print with plot styles" is checked. When I chose "save as pdf" or "open pdf with preview" in the lower left corner, I do get a pdf, but it is not grayscale and is of low quality.
I have read over threads related to this issue and still haven't found a solution.
Solved by maxim_k. Go to Solution.
The properties pallette for the viewport in the properties inspector indicates the shade plot is "as displayed" The problem persists.
Here are the instructions:
- activate Model space
- open Properties Inspector, ensure that nothing selected, on "Current Properties" tab find Plot Style section, then Plot Style Table
- open drop-down list and select monochrome.stb
- switch to Layer Properties tab in Properties Inspector and find "Plot style"
- select "Style 1" from list (instead of "Normal"
- at the command prompt type -LAYER (with hyphen before command name) then hit Return, than type PS and hit Return, then type Style 1 and hit Return, then type * (asterisk) an hit Return twice:
Command: -LAYER <- Hit Return here
Current layer: "Dimensions"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: PS <- Hit Return here
Enter Plot Style Name or [?] <Style 1>: Style 1 <- Hit Return here
Enter name list of layer(s) for plot style name Style 1 <Dimensions>: * <- Hit Return here
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: <- Hit Return here
Now go back to the Layout and try to plot.
Maxim
Hi @risha_chitalia ,
You can create Grayscale STB Plot Style table file yourself:
- open monochrome.stb file in Plot Style Table Editor, use "Save as" button to save it under another name, for example - Grayscale.stb
- select "Style 1" Plot Style on the left, change Color to "Use object color" and check-mark "Grayscale" option
- pick on "Save & Close" button
- assign this new "Grayscale.stb" to the Layout you want to print
- change "Plot Style" property of all Layers in the drawing to "Style 1"
- print your drawing:
Just in case I have attached an archive with ready for use "Grayscale.stb" file
