A small query here that no doubt has a simple answer.
My drawing seems to have developed blue circles along one particular spline. I don't know if something has become turned on by accident or what. But they seem to persist whatever i do. When Regenerating the drawing, they just change scale, and are there regardless of selection of the item.
If anyone could suggest how i could get rid if these i would appreciate it!
Thanks.
Solved by maxim_k. Go to Solution.
They appear all the time. They are in the same position as the vertices. But when selecting the spline they just change scale and carry on persisting.
unfortunately, I won't be able to post the dwg due to the content. Screenshots of the particular spline are the best I can do. (sorry!)
Pasting into a new dwg doesn't seem to recreate the problem interestingly.
well...I wouldn't consider it a fix (barely a workaround). Especially if would have to transfer an entire drawing to another file. Which would then lose all the groupings etc.
I was hoping there would be a solution in case something similar happened again as it seems a bit of a bug.
But thanks anyway.
Don't worry I understand that isn't how bug reporting works. (Hence why I said it 'seems' like a bit of a bug. ) Thanks for the helpful tip though.
Hopefully I will be able to recreate it some time and we can figure out what is going wrong.
Nothing much discovered either. I do understand how it is very difficult without the dwg. Worth a try though! Bit of a dead-end for us all at the moment.
You too! 🙃
Hello again!
So autocad seems to have been quite laggy since the previous post. Even after re starts. Which seems like it could be connected. This is the case even with an empty file, so doesn't seem to be as a result of a heavy file. I think i will go for a re-install and see if that helps.
Anyway, I have attached a file with a spline that had the issue occurring to. I'm not sure if once re-opening the file it the circles come back. But there could be something there that an expert eye might notice.
Thanks.
Clearing the recent blocks seems to have been a big help. Interesting, thank you! Any idea of why that causes problems?
>>>>No issues on my side.
Strange.
Interesting. I'll be honest, it isn't a feature i have used at all. But will keep an eye on the issue in the future!! Perhaps the issue with the vertices persisting was connected in some way? Something to do with the lagging etc.
Anyway, Thanks again.
"...can't be a bug if we don't have your DWG file..." I think you just changed the definition of a bug.
"...that's not how bug reporting works..." He found a bug and reported it?!? The reporting of the bug worked just fine. It may not get fixed, but most of the most useful workarounds I find are from 10 year old threads regarding bugs that never got fixed, so that's not a big loss.
"...friend." That guy does not need enemies.
When I experienced this graphical glitch it resolved itself with a restart, so it was a different issue with similar symptoms.
