iLast minute discussion before ordering.
Talk with Apple about M1 Pro vs Max: https://omegle.onl/
“I’m in robotics-3d modeling, machine learning and software engineering and yes on college. Do I need the max?”
Apple employee said I should be getting the max with my 16” is he/she correct? I’m hoping to order today. I’m leaning towards the M1 Pro for battery and heat reasons. I just don’t want to make the wrong decision. I’m also hoping to have Apple expedite my order since this is a replacement issue.
Solved by maxim_k. Go to Solution.
Hi @tribangen ,
When using AutoCAD, you will not notice any difference between Pro and Max versions of M1 chip, so you should decide based on your other software / applications needs.
Hello, @tribangen, I just accepted your post's answer as a solution, knowing that it's an appropriate answer that will save other users time. In the future, you may also click the "Solution" button when appropriate so that other users can benefit from this information. Please let me know if you have any questions!
