Issue converting dwg file to stl
ccstreib
Observer Observer
ccstreib
Observer
Observer
Hi I have been having trouble converting my dwg file to stl in order to 3d print. Could someone help me with this please. I would really appreciate it
maxim_k
Hi @ccstreib ,
STLOUT command works only with solids or watertight meshes.
There is no solids or watertight meshes in your drawing, so AutoCAD cannot create STL file from the objects in this drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ccstreib
Observer
Observer
Hi Maxim_k thanks for the response. Is there anyway to make the file
compatible with 3d printing?
Best wishes
Cody
maxim_k
Cody,
I converted your drawing to STL with Rhino for Mac, as it can export open objects to STL.
Not sure if the resulting STL will be compatible with 3D Printing device.
See attached STL, it is in binary format.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ccstreib
Observer
Observer
Hi Maxim_k
Thank you so much for the help. I will give that a try and see if it works.
I will let you know how it goes. I really appreciate the help!
Best
Cody
