insert block with default layer
ruirego
Message 1 of 12
ruirego
hi all!
when i insert a block it always stays in the active layer.
is there a way to set a default layer of a block, so when i insert the block it stays in that layer (not the one that's active)
thanks
r^2
Replies (11)
Message 2 of 12
h_s_walker
Create a toolbar button for your block. See the image below
Howard Walker
Left Handed and Proud
Message 3 of 12
ruirego
hello,
how do i do that in the LT Mac version?
r^2
Message 4 of 12
h_s_walker
Ask in the MAC forums. The link is below
AutoCAD for Mac
Howard Walker
Message 5 of 12
ruirego
but this is the Mac forum
Message 6 of 12
h_s_walker
You originally posted in the LT for Windows forum and a moderator has moved it here
Howard Walker
Message 7 of 12
ruirego
thank you,
there should be a forum for Mac LT
Message 8 of 12
pendean
Community Legend
Community Legend
@ruirego It is now in the MAC forum because your post was moved from the wrong forum into this correct forum only a few moments ago.
MAC forum is for AutoCAD and LT together: there is not enough volume of users for each to justify separate forums.
Message 9 of 12
maxim_k
Hi @ruirego ,
As there is no special system variable for the default layer for INSERT command, you can a macro for each block you want to insert on a special layer and assign it to Tool Sets palette button or to drop-down menu item.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 12
maxim_k
The macro itself could be:
^C^C-layer;set;BLOCKLAYERNAME; _INSERT;BLOCKNAME;\;;;_LAYERP
Where BLOCKLAYERNAME is the name of the layer for block insertion and BLOCKNAME is the block name you want to insert.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
ruirego
thanks Maxim,
to advanced for me... can make it easy
i'll manually change the layer after inserting block, or just copy paste existing...
thans again
r^2
Message 12 of 12
maxim_k
Yes, this is one of the ways...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
