Dynamic Input not working - AutoCAD LT 2019.2.1 on macOS Ventura 13.2.1
robolmo
Message 1 of 9
robolmo
My autocad LT 2019 has been rendered almost useless since I updated to macOS Ventura – I can only make entries while the cursor is directly over the command bar.  I have tried returning all settings to default, DYNMODE set to <3>, DYNPROMPT set to <1>  All to no avail.  There seems to be no updates available as have been in the past to reconcile with macOS updates.  I have a stand alone license rather than a subscription – so I cannot simply update to LT 2023.
Please let me know if any fix is available, or imminently on the horizon.
Thank you!
robolmo63
Replies (8)
Message 2 of 9
maxim_k
Hi @robolmo ,
AutoCAD LT 2019 is not compatible with macOS Ventura and there will be no updates for it, because Autodesk releases updates only for 3 last AutoCAD versions. For now these versions are 2023, 2022 and 2021.
So it seems the only one way for you to continue to use 2019 version is to downgrade macOS on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
cdarrigo
Community Visitor
Community Visitor
I have AutoCAD 2022- same issue, commands will not work ...any help would be wonderful
Message 4 of 9
maxim_k
Hi @cdarrigo ,
You need to install this Update:
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=AUTOCAD_MAC_2022_3_1_FIXED_ISSUES
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
elysa27Y2Z
Observer
Observer
I'm using AutoCAD 2022 LT on a Mac Pro - Ventura 13.2.1 operating system. When I click to check for updates, I don't receive a banner. I logged into my Autodesk account, and the attached image is the only update shown. I performed this update, and I'm still having issues. I can't use the stretch command or the move command, amongst many other issues. My lines extend forever at an angle. Please help!
Message 6 of 9
wei503
@elysa27Y2Z please open the macOS System Preference, and go to the Notification setting page, check if you allow AutoCAD LT 2022 to send notifications. It should look like below.Screenshot 2023-03-10 at 09.42.18.png
Wei Ma
AutoCAD QA Manager
Message 7 of 9
elysa27Y2Z
Observer
Observer
You rock!!! Thank you so much for your quick reply. After I turned my notifications on, I was able to download the hot fix. Appreciate your help!!!
Message 8 of 9
annelbrewer
Community Visitor
Community Visitor
I have mac os Ventura 13.5.1 and autocad LT for mac 2021... since updating the OS cad won't work at all. What do I do?
Message 9 of 9
maxim_k
Hi @annelbrewer ,
2021.3 Update
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
