Hi, I've recently had to completely remove everything on my computer including the Operating System. Since I've reloaded everything including AutoCAD LT for Mac I cannot load the w-blocks from my CAD library whereas previously it was not a problem. Can anyone help?
Hi Victor,
If you are using AutoCAD 2022 now, then you need to study the changes that have occurred in Block libraries feature in 2022 version:
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-C1551EC5-2B05-423C-A485-0838E325535E
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-D8130EE9-1056-4048-A7AB-06D7297B6597
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-09389064-395E-4D18-99CF-7F6C18718EF3
HTH
Hi everyone, thank you for your replies but I don't think I made myself clear. The vast majority of the blocks I want to import are greyed out now I've reloaded the OS etc including AutoCAD whereas before I had to reconfigure the computer they were all accessible. If anyone can help to overcome this issue I would be appreciated.
@Anonymous ,
Where they are "Grayed out"?
Can you provide the exact steps you take to add blocks to Block libraries? It will be better if you illustrate these steps with screenshots.
