AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Import library blocks
8 REPLIES 8
Message 1 of 9
400 Views, 8 Replies
Hi, I've recently had to completely remove everything on my computer including the Operating System. Since I've reloaded everything including AutoCAD LT for Mac I cannot load the w-blocks from my CAD library whereas previously it was not a problem. Can anyone help?
8 REPLIES 8
Message 2 of 9
pendean
LT year version is...?
MacOS version is...?
Method you are using to " load the w-blocks from my CAD library" is...?
Message 3 of 9
maxim_k
Hi Victor,
If you are using AutoCAD 2022 now, then you need to study the changes that have occurred in Block libraries feature in 2022 version:
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-C1551EC5-2B05-423C-A485-0838E325535E
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-D8130EE9-1056-4048-A7AB-06D7297B6597
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-09389064-395E-4D18-99CF-7F6C18718EF3
HTH
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 9
in reply to: pendean
Hi, I'm using AutoCAD LT 2021 for Mac with OS Big Sur 11.2.3
Message 5 of 9
Hi, I'm using AutoCAD LT 2021 for Mac with OS Big Sur 1.2.3
Message 6 of 9
maxim_k
If you are using 2021 version, then the process of adding block libraries is the same as in previous versions.
You can add your existing block library files on Block Libraries tab of Blocks palette:
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-09389064-395E-4D18-99CF-7F6C18718EF3
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-350F4101-6108-4AA8-810B-376442622901
Can you describe your workflow in more details?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
Hi everyone, thank you for your replies but I don't think I made myself clear. The vast majority of the blocks I want to import are greyed out now I've reloaded the OS etc including AutoCAD whereas before I had to reconfigure the computer they were all accessible. If anyone can help to overcome this issue I would be appreciated.
Message 8 of 9
maxim_k
@Anonymous ,
Where they are "Grayed out"?
Can you provide the exact steps you take to add blocks to Block libraries? It will be better if you illustrate these steps with screenshots.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
in reply to: maxim_k
Hi everyone,
I’ve managed to resolve the issue by removing the blocks which for some reason when I reinstalled AutoCAD all the blocks were in the Cloud.
By removing them from the Cloud they are now all accessible in the normal way.
Many thanks for everyone’s help.
