AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
how to move the weight center of an irregular object to origin (0,0,0) in AutoCAD for Mac
3 REPLIES 3
LeoImLeo
330 Views, 3 Replies
I have plotted a few objects in one file, for example, 1 desk and 4 chairs.
Now I wanna AutoCAD for Mac to automatically find the weight center of the desk, and move this center to origin (0,0,0), and ignore the remaining part (4 chairs for example).
How can this be done?
3 REPLIES 3
maxim_k
in reply to: LeoImLeo
Hi @LeoImLeo ,
What do you mean by "weight center of the desk"?
If it is Geometric-Center, then you can use MOVE command to move the "desk" object using this command sequence:
Command: MOVE
Select objects: 1 found <- Select desk
Select objects: <- Hit Return
Specify base point or [Displacement] <Displacement>: _gcen of <- Use Geometric Center object snap
Specify second point or <use first point as displacement>: #0,0 <- Type this and hit Return
HTH
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
LeoImLeo
in reply to: maxim_k
Hi @Maxim ,
Yes it is Geometric-Center, then I use MOVE command to move the "desk" object using this command sequence:
Command: MOVE
I have a problem with this step:
After typing "_gcen", "of" will appear after typing space, then how can I snap the full object? It does not show a small green triangle of central part of an object.See my attached screenshot.
maxim_k
Hi @LeoImLeo ,
Geometric-Center works only with closed polylines and splines as stated here:
https://help.autodesk.com/view/ACDMAC/2022/ENU/index.html?guid=GUID-A782462F-F85C-4496-85A5-3D9A5454...
So you cannot use Geometric-Center OSNAP directly on 3D Solid in your drawing.
You can use 3D Object Snap to snap to the center of the face - "_zcen":
https://help.autodesk.com/view/ACDMAC/2022/ENU/index.html?guid=GUID-06D81B23-B171-4F33-920B-4609E22D...
If you need use Center of Gravity as base point, then on Mac you can only get it's approximate coordinates with MASSPROP command. In AutoCAD for Windows you can use AutoLISP routine with ActiveX interface, which is not available on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
