Hello everyone.
So I have a big problem now. I have searched the Forums but I haven't found a solution for this specific problem. I hope you can help me out.
How can I overcome this problem? I spent many many hours preparing these curves so I could turn them into a solid 3D terrain, so I can cut it using a 3D milling machine.
Thank you so much if you can help me!
Below, I will attach pictures and a .DWG file
Light grey is the solid, and the dark grey is the unextruded regions.
Solved by maxim_k. Go to Solution.
Thank you very much for your answer. So it seems that there is a bug in this Autocad version.
I will try to Download 2016 version.
Will it affect how My current Autocad 2018 works? or if I install it will AC 2018 be overwritten?
Thank you Maxim
I downloaded 2016 version and managed to extrude most splines. However, there were 6 lines remaining that I could not extrude somehow. My mac is already slow, so maybe it does not perform well.
Could you be so kind to extrude these remaining splines with 1m up? I cannot find other solutions
Thank you so much for the help. Let's hope next Autocad updates fix this bug (How do I get developers to see this?).
Here it is.
Thank you Maxim! This was a lifesaver.
I marked your previous answer as a Solution.
You may extrude more complex regions if you explode the region, create a closed polyspline and then select the polyspline and then extrude. I managed to extrude some more than the region to solid method was not able. (This way other users can see the multiple solutions if they find the same problem as me). But then again, there was still those 6 lines that I could not manage to extrude.
