luis-pl
en respuesta a: maxim_k
Thank you Maxim! This was a lifesaver.
I marked your previous answer as a Solution.
You may extrude more complex regions if you explode the region, create a closed polyspline and then select the polyspline and then extrude. I managed to extrude some more than the region to solid method was not able. (This way other users can see the multiple solutions if they find the same problem as me). But then again, there was still those 6 lines that I could not manage to extrude.
