AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
How do I change the crosshairs color in the block editor?
16 REPLIES 16
Message 1 of 17
tuttle425
2582 Views, 16 Replies
I changed the background color of the block editor to match the regular model space background color.  However, the crosshairs are black so it's close to black on black.  How do I change the color of the crosshairs?  FYI, I am using Autocad LT for Mac.
Tags (1)
16 REPLIES 16
Message 2 of 17
rkmcswain
in reply to: tuttle425
If only you weren't using "LT", this might work for you.
I don't see another way in the Mac version, at least by looking at the documentation.
Perhaps @maxim_k might know.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 17
maxim_k
Hi Tim,
For AutoCAD LT you can change Block Editor crosshairs color by editing AutoCAD LT preferences file or with Terminal commands.
What AutoCAD LT for Mac version are you using?
I suspect it is 2021, but I have to be sure of that. It is necessary for the proper preparation of the command for the Terminal.
Please specify also what color you need for crosshairs in Block Editor.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 17
tuttle425
in reply to: maxim_k
Yeah, 2021 for Mac.  I want it to be the same as model space.  White I suspect?
Message 5 of 17
maxim_k
Hi Tim,
You need to quit AutoCAD LT before executing the following commands in Terminal.app.
So, quit AutoCAD, launch Terminal.app and execute this command:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2021\ Standalone/R24.0/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.BEDIT XHAIR COLOR" -int 16777215
You can copy - paste the string above.
Launch AutoCAD and test crosshairs color in Block Editor.
To return back to default color use the following Terminal command:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2021\ Standalone/R24.0/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.BEDIT XHAIR COLOR" -int 0
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 17
rkmcswain
Thanks @maxim_k - looks fairly complex compared to just having this setting in the GUI.
Message 7 of 17
tuttle425
That did it.  Thanks!
Message 8 of 17
tuttle425
in reply to: rkmcswain
It's not complex.  It's just a few clicks.
Message 9 of 17
rafka009
What I need to do, to change color of Crosshairs in Block Editor in Autocad 2023 and 2024 for Mac?
Or what I need to type in Terminal to done it?
Message 10 of 17
maxim_k
in reply to: rafka009
Hi @rafka009 ,
If you have full AutoCAD version, you can use AutoLISP statement to change crosshair color in Block Editor.
For example to set crosshair color to red, you need to type at the command prompt:
(setenv "BEdit Xhair color" "255")
and hit Return.
To set the default value - use this:
(setenv "BEdit Xhair color" "0")
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 17
rafka009
Thank you but I use LT versions of Autocad..
Can you help me with those also?
Message 12 of 17
maxim_k
@rafka009 ,
Yes, you can use my instructions from >>>>this<<<< post, just substitute AutoCAD\ LT\ 2021\ Standalone/R24.0 with
AutoCAD\ LT\ 2023\ Standalone/R24.2 - for AC LT 2023
or
AutoCAD\ LT\ 2024\ Standalone/R24.3 - for AC LT 2024
So for 2024 version it should look:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2024\ Standalone/R24.3/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.BEDIT XHAIR COLOR" -int 16777215
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 17
rafka009
Thank you, but still black crosshairs in block editor..
Message 14 of 17
maxim_k
@rafka009 ,
Give me some time, I need to check my instructions in AC LT installation.
I can check with AutoCAD LT 2024 for Mac. What version do you have?
And what color do you want for crosshairs in the Block Editor?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 17
rafka009
I have 2023
and 2024 but I checked only on 2023 now.
lets say geen color of crosshairs but I understood that I can try any color depends on number of color?
Message 16 of 17
maxim_k
@rafka009
Yes, you set the color by numeric value, but this value is a bit tricky to calculate.
I have AutoLISP routine which can calculate numeric values for UI colors in AutoCAD, but you can use it only in full AutoCAD version. That is why I asked you about color you want.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 17
maxim_k
Hi @rafka009
I checked with AutoCAD LT 2024 for Mac and this Terminal command:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2024\ Standalone/R24.3/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.BEDIT XHAIR COLOR" -int 65280
sets the color of the crosshairs in Block editor to green:
To revert back you need to quit AutoCAD LT and execute the following command in the Terminal.app:
defaults write ~/Library/Application\ Support/Autodesk/AutoCAD\ LT\ 2024\ Standalone/R24.3/local/HKCU_V1.plist "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.PROFILES.<<UNNAMED PROFILE>>.DRAWING WINDOW.BEDIT XHAIR COLOR" -int 0
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
