Add cursor color setting
betazero
betazero
Please add cursor color setting. I like a uniform background color of 20,20,30 but block editor defaults the cursor to black unless you use a black background. Please just add a cursor color setting in the next version.
maxim_k
Hi Russell,
Which cursor color you need in block editor?
I'll try to help you to set it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
If you need, for example, white crosshairs color inside block editor, type at the command prompt (you can copy - paste this string):
(setenv "BEdit Xhair color" "16777215")
and hit Return.
To return back to the default color, type at the command prompt:
(setenv "BEdit Xhair color" "0")
and hit Return.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
betazero
sweeeeet!!! Thank you kind sir 🙂
