Im using Autocad 2019 for Mac. I have several blocks with information like numbers of items per m2. I am not able to do a multiplication from 2 different fields (area * # items/m2), and then I can't figure out how to export this data from those blocks to an excel table. Any clue of how to do this?
Solved by maxim_k. Go to Solution.
Thanks Maxim,
I have seen those videos already, I have linked my table using DATALINK. My problem is that im unable to feed the attribute with the multiplication I've done in excel in order to add the numbers of plants on the polygon area.
I hope I made myself clear. (dwg is attached)
Thanks for your time.
Best case scenario the multiplication should happen on the block itself, but if thats not possible, I was thinking that maybe a linked excel table could do the trick?
One information should come from the area of a polygon, the second information is a value manually inserted on the block... do you think it is possible to do this multiplication within autocad?
thanks.
Ok I will try this way:
- I have a block with attributes, which are fields (The fields are manually inserted by me. Only the area is inserted trough the insert field button)
- Then I want to calculate fields values from this block inside the same block, in this case, the area of the polygon and a manually inserted factor. At the end I want to know how many plants do I need for that specific area.
- Extracting attributes to excel is the way around, since Im not getting how to do the calculations within autocad.
Let me know,
cheers,
Thanks Maxim,
Im quite disappointed that after so many years, Autocad for Mac still presents disadvantages towards windows.
Thanks for your time anyways.
Hello Maxim,
I justo downloaded the 2020 Autocad trial version for Mac in order to try this. I am now able to do the multiplications within the program.
Now, what im struggling with is, how do I create a table that contains all the information from my blocks without exporting the data to excel?
thanks for your help!
Create table with columns which will contain information from block attributes. Each row will contain information from one of the block insertions.
Now put fields to each cell in the row (one field - one attribute value in particular block). When you insert field to the table cell, select Objects -> Object -> Type (use button to the right of the Type list to select block in the drawing area). After you select block with attributes, you will be able to select one of the attribute (by TAG) from Property dropdown under Type dropdown. Select additional format if you need it and click on Choose button to insert Field.
Now you have a field inside table sell with attribute value from block. If you will change attribute value in the block and use REGEN, SAVE, OPEN, PLOT commands (I assume that FIELDEVAL (System Variable) = 31 as it is by default), the value in the sell will be updated according to new attribute value.
I attached rough sample.
Thanks Maxim. The example was very clear.
Im wondering if I need to do this cell by cell, or if I can ask the program to make a table out of the blocks and fill my table automatically?
thanks
