AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
what happened to ATTOUT?
4 REPLIES 4
6674 Views, 4 Replies
When I try to extract the attribute information from a group of blocks, in order to export to a spreadsheet, I select the blocks, type ATTOUT, and get the message "unknown  command" How can export/import attribute data in ACAD Mac?
4 REPLIES 4
maxim_k
This command is from Express Tools, which are not available in AutoCAD for Mac.
Currently you can use only command line version -ATTEXT (with hyppen) to extract attributes.
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Is there a good set of instructions for doing this procedure?  The ones on this site are very unclear....
I have been evaluating autocad for MAC 2014 only today!, it is the third instance I find the same answer. Let me clarify, I was looking for different subject matters though. Maybe you can recommend "go to google maps instead of mac maps"; just as Tim Hook did some months ago. It would be hilarious you end up buying Parallels and selling bundled packages by the name of:  "Autocad for MAC".
Oh well, I can go on and on, I have not reached the LISP programming language yet, friends have told me good luck, but I don't need it, you do.
Greetings from México
maxim_k
Welcome to the Autodesk Forums!
Here you can find short tutorial about attribute data extraction in AutoCAD for Mac:
I also attached files to complete this tutorial.
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
