Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
divide multiple lines
9 REPLIES 9
Message 1 of 10
ruirego
302 Views, 9 Replies
hello, any way to select several lines and divide all? now that Autocad Mac as LISP maybe its possible!?
thanks
R^2
9 REPLIES 9
Message 2 of 10
maxim_k
in reply to: ruirego
Hi @ruirego ,
Do you mean DIVIDE command where you get points or blocks along an object (lines)?
How are these lines located relative to each other? Can you provide screenshot?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
maxim_k
If you need to divide LINEs from selection set of objects, try to use something like this:
(defun c:Multidivide ( / oldcmd ss1 num)
(setq oldcmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(defun sstolist (ss / sscnt)
 (setq sscnt 0
sslist nil)
 (repeat (sslength ss)
  (setq sslist (cons (ssname
ss sscnt) sslist))
  (setq sscnt (1+
sscnt))
 (princ)
(prompt "Select objects to divide: ")
(ssget)
(setq ss1 (ssget "P" '((0 . "LINE"))))
(sstolist ss1)
(setq num (getint "Enter the number of parts to divide: "))
(foreach n sslist (command "DIVIDE" n num))
(setvar "CMDECHO" oldcmd)
(princ)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 10
ruirego
in reply to: maxim_k
hello, yes its the command DIV.
a can make line by line, but it would be better if i could select several lines, and DIV all at the same time.
in the screenshot attached in pink there are several lines
R^2
Message 5 of 10
maxim_k
@ruirego ,
Try THIS LISP.
It prompts to select objects, filters lines from the selection set, asks for a number of divisions and divide selected lines.
You may need to adjust point style to see the results.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 10
ruirego
here do i paste this code?
Message 7 of 10
maxim_k
No, download attached LSP and use APPLOAD command to load it to each drawing.
The command name is Multidivide
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
ruirego
Hello Maxim, i'm in Autocad LT 2024 for Mac
can i do this LISP?
tks
Message 9 of 10
maxim_k
@ruirego
You asked about LISP and didn't mention that you use AutoCAD LT for Mac.
AutoLISP is not a feature of AutoCAD LT for Mac, unfortunately you cannot use AutoLISP in AutoCAD LT for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 10
ruirego
thanks Maxim!
