maxim_k
en respuesta a: ruirego
If you need to divide LINEs from selection set of objects, try to use something like this:
(defun c:Multidivide ( / oldcmd ss1 num)
(setq oldcmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(defun sstolist (ss / sscnt)
 (setq sscnt 0
sslist nil)
 (repeat (sslength ss)
  (setq sslist (cons (ssname
ss sscnt) sslist))
  (setq sscnt (1+
sscnt))
 (princ)
(prompt "Select objects to divide: ")
(ssget)
(setq ss1 (ssget "P" '((0 . "LINE"))))
(sstolist ss1)
(setq num (getint "Enter the number of parts to divide: "))
(foreach n sslist (command "DIVIDE" n num))
(setvar "CMDECHO" oldcmd)
(princ)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
