Costumava usar o MagicPrefs. Porém ele parou de funcionar.
O que devo fazer?
Grato.
Solved by maxim_k. Go to Solution.
HI @Anonymous,
Please forgive me if I misunderstand your question as I am machine translating it to English. If I understand correctly, you are experiencing problems with your Magic Mouse and AutoCAD for Mac. Please tell me which version of AutoCAD you are using. Please also tell me if you any idea of the actions that might have caused this or occurred at the same time. For instance, did you just upgrade to MacOS HighSierra? The OS upgrade has been known to cause some problems and the easiest resolution is to uninstall and then reinstall your application.
Hi @Anonymous,
I am checking back to see if @maxim_k helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
