AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Como usar pan com magic mouse
4 REPLIES 4
1203 Views, 4 Replies
Costumava usar o MagicPrefs. Porém ele parou de funcionar.
O que devo fazer?
Grato.
4 REPLIES 4
john.vellek
HI @Anonymous,
Please forgive me if I misunderstand your question as I am machine translating it to English. If I understand correctly, you are experiencing problems with your Magic Mouse and AutoCAD for Mac.  Please tell me which version of AutoCAD you are using. Please also tell me if you any idea of the actions that might have caused this or occurred at the same time. For instance, did you just upgrade to MacOS HighSierra?  The OS upgrade has been known to cause some problems and the easiest resolution is to uninstall and then reinstall your application.
John Vellek
maxim_k
Welcome to Autodesk Forums!
Hi Grato,
here is the information from MagicPrefs site:
"MagicPrefs is more than 5 years old now and is no longer mantained, the functionality it provided was made possible by Api's that are now deprecated and reverse engineered private Apple frameworks. Apple is not likely to replace the deprecated Api's nor provide access to the underlying multitouch technology so that's the end of the line for MagicPrefs and similar software.
TLDR if it doesn't work anymore thats it, if it still works then its just a matter of time until it won't."
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @Anonymous,
I am checking back to see if @maxim_k helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Solo toca el space bar.
