AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Can't seem to extract data properly.
2 REPLIES 2
549 Views, 2 Replies
Hello, all. So I'm working on extracting data from W-Blocks as part of a school assignment in Autocad for Mac. I've made the W-Blocks, put them into one complete object, created an extraction template, and now I'm just trying to extract the data into a chart. The only problem is, nothing happens when I try to extract in Cdf and Sdf format.  It works for Dxx (granted, it's a jumbled mess) but nothing else. For the life of me, I cannot see what I am doing wrong. I have attached the drawing and the template to this post. If someone could assist me with this, I would really appreciate it. I've spent days trying to figure this out.
Thank you in advance.
2 REPLIES 2
maxim_k
Welcome to Autodesk Forums!
Hi Joshua,
Extraction template should be without extra carriage returns at the end of the text file (yours has 3 CR at the end).
Plus:
- BL:NAME should be in upper case
-  Maximum field length and Decimal places should have 3 digits for each
Look at the attached template "Extraction Template-2.txt" - it should work with your drawing.
The result I got is in "DWG 3 - WBLOCK TEST FIXTURE.txt" file
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Sir, you are a gift among men. Thank you so much. On an unrelated note, may I ask what you think about AutoCAD for Mac? Do you think Windows is better? Would you ever really need to use Mac? I ask because I'm trying to draw on the knowledge of people with far more experience than me (I've only been using AutoCAD for Mac for a few months).
