maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Joshua,
Extraction template should be without extra carriage returns at the end of the text file (yours has 3 CR at the end).
Plus:
- BL:NAME should be in upper case
-  Maximum field length and Decimal places should have 3 digits for each
Look at the attached template "Extraction Template-2.txt" - it should work with your drawing.
The result I got is in "DWG 3 - WBLOCK TEST FIXTURE.txt" file
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
