Autocad LT for Mac 2025 Crash whenever batch publish
iamshanice
1 830 Visites
11 Réponses
Message 1 sur 12
iamshanice
I was using Autocad LT for Mac 2024 and I recently downloaded 2025 version for a try in parallel, however it crashes whenever I do batch publish.
my mac OS is Sonoma 14.6.1.
Anyone experienced the same and got a solution? Many thanks!
0 J'aime
Solutions acceptées (1)
1 831 Visites
11 Réponses
Replies (11)
Message 2 sur 12
iamshanice
I changed the graphic drive to OpenGL then it can batch publish, but the graphics are far less smooth then Metal, so sad...
0 J'aime
Message 3 sur 12
maxim_k
Hi @iamshanice ,
What Mac model do you have?
Have you installed the latest Update to AutoCAD LT for Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 J'aime
Message 4 sur 12
iamshanice
Macbook Pro 2023, Sonoma 14.6.1
I downloaded the update , but seems it is already installed automatically when I installed the Autocad LT for Mac 2025 today.
0 J'aime
Message 5 sur 12
maxim_k
@iamshanice ,
So you have Mac with M series chip. The native graphics engine for it is Metal.
Plus - I'm not sure if the graphics engine type can affect batch publishing.
@iamshanice wrote:
... seems it is already installed automatically when I installed the Autocad LT for Mac 2025 today.
Updates to AutoCAD for Mac are never installed automatically. You can check AutoCAD version in "About AutoCAD" window:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 J'aime
Message 6 sur 12
iamshanice
My verion is 2025.1
0 J'aime
Message 7 sur 12
iamshanice
My verion is 2025.1
0 J'aime
Message 8 sur 12
iamshanice
Tried to install the update, but it says it is already installed.
0 J'aime
Message 9 sur 12
iamshanice
I may install macOS Sequoia and try
0 J'aime
Message 10 sur 12
maxim_k
Solution acceptée
Please look here:
Plotting fails, does nothing, or crashes AutoCAD for Mac
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 sur 12
iamshanice
thank you so much, problem solved, it really is the font problem, I removed the error fonts, and removed the objects using those fonts, and it publishes fine now.
0 J'aime
Message 12 sur 12
iamshanice
Finally resolved !! Thanks to a webpage sharing the fonts problem solved by using Typelight, simply download Typelight, use Cmd +O to open the problem font, and modify all non-English name, save as a new font in the /fonts folder. And edit the font style using the problem font in Autocad, assign the style to the new font. I can now use Metal as graphic driver and batch publish without crashing again.
0 J'aime
