Hello all
I'm having a re-occuring problem hoping to get some help with. While working on architectural and MEP working drawings i often "save as" many time to create backups in case i want to go back to an old file. It not uncommon for me to have 30 dwg files for one building project. The files never get huge but in the case of what is happening to me today i have about a 4.5 mb file that i'm working in everything going fine. I decide to edit this file by removing alot of info i dont want / need anymore. Whenever i do a save as the file size jumps up to 5.5 mb or so and all of a sudden the drawing file becomes very difficult to work in with every move or selection lagging significantly. Example: i go to select a number of objects and my cursor just drags out the process, taking way longer than typical to select objects, copy objects, move, or draw new.
I'm running high sierra 10.13.6, ACAD LT 2018, everything is up to date
i have already tried the following:
In AutoCAD, using the command line, set the following variables to zero:
DYNMODE
scutil --set HostName $(scutil --get LocalHostName)
