Hi guys,
I have an imperial template file that i want to use for a metric project. for the units conversion i am using [-DWG] command.
1/ Trying to understand the "Scale objects from other drawings upon insert" prompt. If i select yes and import an object that is 1' from an imperial drawing will it be scaled to the metric drawing as 0.304M?
2/ Trying to understand the "Scale in current drawing to reflect change in units" prompt. If i select yes and will an object that is 1' become 0.304M in my new metric drawing?
3/ How do i make the hatches reflect the new Metric standards ?
4/ I there anything other than the:
-DWG command prompts
INSUNITS
Sheet to Metric standard sizes
Scale Paper space template to match new metric sheet
Viewport scales to metric
Dimension style
Anything else i need to change for a proper conversion ?
