AutoCAD Compatibility with OS X El Capitan (10.11)
wei503
Community Manager Community Manager
Message 1 of 265
wei503
Apple has announced the next OS X El Capitan earlier today, and the first preview version is already available for app developers. AutoCAD team is starting to analyze the compatibility on this OS and preparing to fix the potential issues.
Some of AutoCAD users may have access to the El Capitan preview version, and would like to test AutoCAD on it. Please kindly post any of your findings in this thread, that would help other users and also the AutoCAD team.
Please include the following info in your posts for reference:
-OS X version(for example, DP1 15A178w)
-AutoCAD version
The AutoCAD for Mac Team
Update:
The updates for AutoCAD and AutoCAD LT 2015/2014 to fix the compatibiliy issues on El Capitan are available. You can click menu AutoCAD or AutoCAD LT > Check for Updates to download it. You can also go to pages below to download the update:
AutoCAD 2015 Update 3:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2015...
AutoCAD LT 2015 Update 5:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
AutoCAD 2014 for Mac SP4: https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2014...
AutoCAD LT 2014 for Mac SP4: https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
Wei Ma
AutoCAD QA Manager
Replies (264)
Message 21 of 265
dr.palmer
Using AutoCad Mandalore with MacOSX 15A278b, not seeing any problems as of yet.
Message 22 of 265
Crashing with the same El Capitan build as you and LT14 seems to be when I
insert either a template or text. It can work for quite a while and
then.......poof !
Message 23 of 265
Autocad 2015 with El Capitan 15a278b crashes too on loading screen. How can i resolved it?
I have imac 27" late 2012 - 24gb ram
Thanx
Message 24 of 265
AutoCad Mandalore has full screen issue.
If you click full screen button, there is no way to exit (or i cant find it =))
Message 25 of 265
I dont believe you can, its compatability issues with the Beta programme
and Autocad. You will either have to wait for it to be resolved or ( like
me ) go back to using Yosemite.
Message 26 of 265
dr.palmer
It has'nt been setup to use the usual keystrokes to exit full screen, yet.
Remember this is a Beta, improvements will come to pass.
In the mean time, goto your screen corner that you have set to show apps that are running.
Then hover over the screen icon of AC and a set of arrows pointing inward will show up.
Click on the arrows and then click on the AC item that appears and your screen will come back as a normal view.
I know it's an hassle to do this versus the keystrokes, but don't give up.
DP
Message 27 of 265
Autocad Mandalore now has not any full screen issue with service pack 1.
Many Thanx Autocad Team,
P.S. "I am waiting for some updates for Autocad 2015, which will be working with El Capitan."
Best Regards,
Ugur
Message 28 of 265
I am using AutoCAD 2015 with the latest OS X El Capitan GM Candidate for commercalization (Macbook Pro Retina Intel HD Graphics 4000)
and it is still constantly crashing: either just by opening a new file, or when I want to add layers (!) - any updates on the problem? Thank you for your help...
Message 29 of 265
dr.palmer
The current version of AutoCad Mac 2015 is   J.51.M.313
Message 30 of 265
Having the same issue on my 2012 MAC ever since downloading the El Capitan GM operating system. My AutoCAD 2015 continues to crash every time I try to edit any text. Hope they resolve this soon ;-(
Message 31 of 265
dr.palmer
Here's Acads' requirements for 2015
Apple® Mac® OS® X v10.8 or later (Mountain Lion); OS X v10.9 or later (Mavericks); OS X v10.10 or later (Yosemite)
Apple Mac Pro® 4,1 or later (Mac Pro® 5,1 or later recommended); MacBook® Pro 5,1 or later (MacBook Pro 10,1 with Retina Display or later recommended); iMac® 8.1 or later (iMac 11.1 or later recommended); Mac Mini 3.1 or later (Mac Mini 4.1 or later recommended); MacBook Air® 2.1 or later; MacBook® 5.1 or later (MacBook 7.1 or later recommended)
64-bit Intel CPU (Intel Core Duo CPU, 2 GHz or faster, recommended)
3 GB of RAM (4 GB recommended)
2.7 GB free disk space for download and installation (4 GB recommended)
All graphics cards on supported hardware
1,280 x 800 display with true color (2880 x 1800 with Retina Display recommended)
Apple Safari 5.0 or later
All Mac OS X supported language operating systems
Apple® Mouse, Apple Magic Mouse, Magic Trackpad, MacBook® Pro trackpad, or Microsoft-compliant mouse.
Download and installation from DVD
Mac OS X-compliant printer
Message 32 of 265
Reinstall autocad it will correct itself with new installation files
Message 33 of 265
Message 34 of 265
Just reinstall it will correct it self with new installation files i did it
last night
Message 35 of 265
yes, im having to edit the text using the properties bar.
Urooz Virk
999 99 13771
Message 36 of 265
CRASH ALL THE DAYS WHEN I OPEN THE FULL SCREEN,  ADD HIDDEN LINES, SPLINE AND SO MANY ANY OTHER FUNCTION.
IT OCCURS AT THE NEWEST VERSION OF AUTOCAD 2015. I HOPE THA THE PROBLEM CAN BE SOLVED ASAP. THANKS
MBPR 2014 (LATE VERSION) , THE LASTEST VERSION OF PUBLISH BETA MAC OS EL CAP.
Message 37 of 265
Autocad LT 2014 is highly unstable and not usable with El Cap. I guess I'll just have to wait and cross my fingers. Otherwise, I'll have to go back to Windows version, which would suck
Message 38 of 265
Don't return to the Windows version if you son't have to...  Especially since the LT subscription is $45/mo (1 month at a time) or $30/mo if you pony up for a full year.  I'm right on the edge of starting up another month.  Since I'm running 10.11.1b1, and the Mandalore Beta is moving along, perhaps the situation has resolved itself...
Message 39 of 265
I have gone back to Yosemite. . But LT 2014 works perfectly now. I will
wait for the situation with El Capitan to be resolved.
Message 40 of 265
carter
I'm not surprised by the issues. Typical AutoCAD/desk... behind as usual with MAC support/updates - where is 2016 btw? The years almost over...
As far as OS X El Capitan 10.11 compatability, is there anything new to report since it's officical release as of today? I was about to upgarde from Yosemite 10.10.5, on iMac '08, using AutoCAD LT 2015 (Desktop Subscription). Reading about OS X El Capitan system requirements I wasnt that worried about third-party apps until I read this and other posts on here. Although I still feel confident it'll run w/o any hiccups.
