AutoCad 2024 LT crashes several times per day
pbje2S92L
Message 1 of 10
pbje2S92L
My Autocad 2024 LT version for Mac crashes several times per day.
My current version is: LT 2024 1.1
Am I the only with crashing issues ?
Some text fonts also are very difficult to select and only can be selected or moved etc. when I give a regen command.
If I want to continue working for a day I better fall back to a previous installed version like 2022 or 2023.
I appreciate any way of help to solve this.
Thanks, Peter Bakker
Replies (9)
Message 2 of 10
paullimapa
Try setting GFXDX12 to 0
If that doesn't help run GRAPHICSCONFIG command & try changing the 2D Display Settings to one of the other modes.
Last option is to disable Hardware Acceleration
https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-14929CF2-8E39-4F87-B8C2-18440B12922E
Paul Li
IT Specialist
@The Office
Message 3 of 10
pbje2S92L
Thanks for your reply Paul.
I maybe mistaking but I am running Autocad for Mac and I do not think this will work for me.
Message 4 of 10
paullimapa
Message 5 of 10
pendean
Community Legend
Community Legend
Exact MacOS version is...?
Files are stored where? And you access that location how?
Are 2022 and 2023 also installed on the same device?
Message 6 of 10
maxim_k
Hi @pbje2S92L ,
As @pendean asked - please specify your macOS version.
Does it crash under certain actions or randomly?
Try to set DTTEXT System Variable to 0 (zero) and test text selection.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 10
pbje2S92L
Hi Maxim, thanks for your reply.
My Mac OS version is Ventura 13.6.1
I still have to install Sonoma, but I wanted to wait until the next Sonoma update.
I never had these kind of crashes with the previous versions like 2022/2023.
I will try the system variable for true type fonts set to 0 and check if this helps.
Message 8 of 10
pbje2S92L
Forgot to mention that I am getting the impression that crashing happens randomly. But I will try to write down when this happens.
Message 9 of 10
seosebt11
If AutoCAD LT 2024 for Mac is crashing frequently, try these steps:
  1. Check System Requirements:
    Ensure your Mac meets AutoCAD LT 2024 requirements.
  2. Update AutoCAD LT:
    Install the latest updates from Autodesk to address bugs.
  3. Graphics Card Drivers:
    Update your graphics card drivers for compatibility.
  4. Workspace and Profile:
    Create a new user profile or workspace to rule out corruption.
  5. Fonts and Plugins:
    Verify font compatibility and disable third-party plugins.
  6. Check for Known Issues:
    Visit Autodesk forums for known issues and solutions.
  7. Contact Support:
    If issues persist, contact Autodesk support for assistance.
  8. Reinstall or Roll Back:
    Consider reinstalling or reverting to a stable version like 2022 or 2023.
Message 10 of 10
maxim_k
Hi @seosebt11 ,
Your recommendations are basically correct, with some exceptions:
1/ >>>>Update your graphics card drivers for compatibility.
There is no separate graphics card drivers updates on Mac. If they happen, then only as part of a macOS update.
2/>>>>Create a new user profile or workspace to rule out corruption.
You cannot create user profiles in AutoCAD for Mac, there is no such functionality on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
