AutoCAD 2024, 2026 only half of screen viewport after macOS Tahoe
garett_rowe273
Message 1 of 48
garett_rowe273
It's always disappointing when a company the size of Autodesk doesn't do his job and test the widely announced newest macOS release. Months of time to correct any bugs, but still you choose to wait and see what happens.
UPDATE 09/26:
The solution proposed by @kclarkePZWHD is the most easier and elegant.
But it can be even simpler:
There’s no need to undock the Palettes or move the command line bar.
Just grab the right side of the command line bar (Picture 1)  and drag it to the end of the screen, passing behind the docked palettes (Picture 2).
Release and done.
Replies (47)
Message 2 of 48
maxim_k
Hi @garett_rowe273 ,
In your screenshot I noticed that you still haven't installed the 2026.0.1 Update.
Not sure that it will help to correct the problem with Tahoe, but anyway...
As for me, I am never in a hurry to install a newly released macOS, usually it still has a lot of bugs.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 48
garett_rowe273
Hi.
Installed by itself unfortunately as the newer versions of macOS are doing lately.
I manually installed the patch that you mentioned, but my version number is still the same than the one in the screenshot.
Problem persists anyway.
Message 4 of 48
maxim_k
@garett_rowe273 ,
For the future: turn off Automatic Updates in macOS System Settings:
Not sure what you mean by "manually installed", but if you installed it, you should see:
 but not this (from your screenshot):
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 48
mdq17
Observer
Observer
Why does it matter if we update early or not? at this price point and with the beta out for months, it's their duty to ensure your software is compatible.
Is there a partial solution? it extremely inconvenient
Message 6 of 48
garett_rowe273
Thank you, @maxim_k .
I installed the latest patch successfully this time, but the issue is still there.
Message 7 of 48
garett_rowe273
Set ALL Palettes to FLOAT instead of docking. Seems to fix for me at least for the moment.
Message 8 of 48
mdq17
Observer
Observer
THANK YOU! worked!
Message 9 of 48
maxim_k
@garett_rowe273 ,
This Update fixes issues with macOS Sequoia, but not with Tahoe.
I only mentioned it because I noticed that you don't have this update installed.
For now - let's wait for a new Update from Autodesk.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 48
pethersonlopes94
Observer
Observer
Here the same thing happened to me… One solution I got was to leave the flap of Layers and Properties floatingly.
Message 11 of 48
c_parri_ext
it's not a fix...!! we need an update!!
Message 12 of 48
c_parri_ext
It’s inconceivable that a software giant the size of Autodesk hasn’t tested the compatibility of its software with the new Mac OS release. It shows little regard for users. Once the product is sold through subscription and the cash is in, what happens afterwards seems to matter very little
Message 13 of 48
chiarialessia99
Observer
Observer
Anche io stesso problema da tutto il giorno. In più non riesco a tracciare linee nei punti precisi che indico ma il puntatore sembra "fluttuare"
Message 14 of 48
rcervantespavon
Observer
Observer
THE SAME ISSUE
Message 15 of 48
marco
Same here. This needs a fix as soon as possible!
macOS 26 is in beta since June...
Message 16 of 48
tiago_s_m_almeida
Community Visitor
Community Visitor
Same problem. Half screen
Message 17 of 48
arpicur
Community Visitor
Community Visitor
Same problem 😞
Message 18 of 48
cossminftw
Community Visitor
Community Visitor
Same fing problem. Is there any official answer for this matter or we should all quit using Autocad for Mac because they cannot patch an issue ?
Message 19 of 48
juangalmez
Observer
Observer
I have the same issue and I'm so close to quit using Autocad and going for another option like archicad
Message 20 of 48
cossminftw
Community Visitor
Community Visitor
i unninstalled 2024 and installed 2025 - works fine now, no image error
