AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD 2018 per Mac slow
26 REPLIES 26
Message 1 of 27
Giovanni_Astrologo
15346 Views, 26 Replies
I have a problem with autocad, it is very slow after restarting the mac after the first installation, the problem persists even after uninstalling and reinstalling again
26 REPLIES 26
Message 2 of 27
What is your MacOS and Mac model?
Message 3 of 27
MacBook Pro retina 2015 13 inch base conf. with macOS high Sierra
Message 4 of 27
Welcome to Autodesk Forums!
Hi Giovanni,
How complex are the drawings you create / edit?
Do you have this problem even with empty, newly created drawings?
Do you use (have) parametric constraints in your drawings? If yes, then try to remove them all and test performance.
What Visual Style you are using in your drawing? If it is other than "2D Wireframe" and you mostly using AutoCAD for 2D drawings, try to change Visual Style to "2D Wireframe" and test the performance.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 27
even with newly created DWG, I use the 2D Wireframe
Message 6 of 27
If you turn off LINESMOOTHING in AutoCAD2018 does the problem go away (or the slowness is not as bad)?
Message 7 of 27
What do you mean by "slow" then?
Does crosshair movement is slow inside drawing canvas? Or something else?
Do you have previous AutoCAD version installed (2017)? If yes, have you migrated settings during installation?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 27
HI @Giovanni_Astrologo,
Please try this:
  • Quit AutoCAD
  • Open the Terminal window, and run the following script (you can copy and paste it in terminal and hit Enter):
      scutil --set HostName $(scutil --get LocalHostName)
  • Input admin password if it asks for permission.
Please let me know if this improves the performance of your AutoCAD session.
John Vellek
Message 9 of 27
dansylvesterRA
in reply to: pendean
Turning off "linesmoothing" did help a lot for me. Are there other tricks like this that I can turn-off? I have a:
2015 iMac Retina
Processor: 4 GHz Intel Core i7
RAM: 32 GB 1600 MHz DDR3
Graphics: AMD Radeon R9 M295X 4096 MB
With "linesmoothing" on, there was a 1-2 second delay every time I entered a new command, changed the zoom, basically anything.
Thanks, DS
Message 10 of 27
in reply to: john.vellek
Thanks! Work's for me too!
Message 11 of 27
Works for me on Autocad 2019 (mac) , Thanks 👍🏻
Message 12 of 27
Hi guys!
I do use a brand new MacBook Pro 15inch i7 16GB and I have this strange thingy; when I select all entities in a drawing (86Kb) and try to zoom in, the system delays and the coloured wheel appears for about 4 seconds before zooming in a little.
I did try the linesmoothing trick, but with no result.
Anyone?
Greetings!
Erwin
Message 13 of 27
maxim_k
Hi Erwin,
Which Visual Style is active in the problem drawing?
Do you have Parametric Constraints in the drawing?
If you don't need Parametric Constraints you can delete them with menu Tools -> Parametric -> Delete constraints (use ALL option to select everything in the drawing).
You can also attach the drawing here - I'll look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 27
maxim_k
If the case is in Parametric Constrains, verify that Infer Constraints mode isn't turned on (icon on Status Bar or Shift+Command+I shortcut toggle).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 27
in reply to: maxim_k
Hi Maxim!
Thank you very much!
See the file as attached.
When you select all the entities, it will slow down the Mek :).
Many greetings!
Erwin
Message 16 of 27
maxim_k
Sorry, but there is no file attached.
You need to reply in browser, not by e-mail in order to be able to attach files.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 27
Try this file right here Maxim, thank you!
Message 18 of 27
maxim_k
No problem with zoom on my side - iMac 21.5 2017
Try to set 2D Wireframe visual style.
Plus: are you aware that objects in your drawing are scattered in three-dimensional space?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 27
Hi Maxim,
Thanks for your reply.
Yes I am aware of the 3D component of this drawing.
We perform BIM2FIELD operations with total stations.
Since two weeks we do work with Apple MacBook Pro computers and as always, we encounter several minor issues like this one.
Good to hear that the file is performing well; I will further check my settings.
Many greetings from The Netherlands!
Erwin
Message 20 of 27
IT WORKS!!!!! AUTOCAD 2018, THANK-YOU.
