Autocad 2018 for Mac (Strange visualization of the grid)
vasco
Message 1 of 13
vasco
I have a problem with Autocad 2018 with my Mac, anyone can help? (Screenshots attached)
Thank you,
VascoSchermata 2018-04-23 alle 23.20.05.pngSchermata 2018-04-23 alle 23.20.14.png
Replies (12)
Message 2 of 13
maxim_k
Hi Vasco,
Do you have this problem from the beginning?
If it appeared suddenly, then: have you tried to relaunch AutoCAD? Restart your Mac? Reset AutoCAD preferences?
Which Mac model do you have?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 13
vasco
Hi Maxim,
I got all these problems with my new Mac Book Pro (15-inch, 2017)
Mac OS Sierra 10.12.6
3,1 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Radeon Pro 560 4096 MB
Intel HD Graphics 630 1536 MB
Thank you,
Vasco
Message 4 of 13
vasco
By the way,
I've reinstalled Autocad and cancelled Preferences, now I'm using Autocad 2017 but as you know I can't for example use the Flatten command as it is only on 2018 version...
Thank you,
V
Message 5 of 13
vasco
One more info,
Schermata 2018-04-24 alle 12.40.14.pngwhen I open a new file (acadiso) even if I'm on millimeters (Units) this is what I see (image attached)
Message 6 of 13
maxim_k
1. >>>>now I'm using Autocad 2017
But in the attached image I see 2018 version. I don't see issue with grid in the image. Have you managed to resolve it?
2. >>>>even if I'm on millimeters (Units) this is what I see
I don't see anything strange in the attached screenshot. Everything seems to be OK with units - decimal with 4 digit precision.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 13
vasco
Hi Maxim,
I was mentioning units in mm just to explain that whatever I see on the screen (image attached) there is a kind of pixel shadow in the background of the polyline (like if it's in a different scale but it's not).
Tks,
Message 8 of 13
maxim_k
So you want to say that in 2017 version on the same machine you don't see any display artefacts, while in 2018, you have this "pixel" glitch?
Do you use external display? I believe - yes. Isn't it?
Try to set system variable LINESMOOTHING to OFF.
Do you see glitches in this case?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 13
maxim_k
You may also look at this topic:
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-2018-graphics-artifacts-on-an-external-...
The topic is in Russian Forum, the OP had the same problem as you with external monitor attached.
And here you can find solution for that topic, provided by Wei:
Or, you can try to play with LINESMOOTHING system variable I mentioned in my prev post.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
vasco
Hi Max,
I did verify and is a monitor problem, great! But if I can't upgrade now where do I find linesmoothing? Can't find it in graphconfig.
Tkss,
V
Message 11 of 13
maxim_k
Just type LINESMOOTHING at the command prompt and hit Return, then type OFF and hit Return again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
vasco
Thank you Maxim!
Message 13 of 13
delio.volpato
Observer
Observer
Dear,
I found another trick, enable a two-view viewport and reduce one
I hope it can help as long as Autodesk fixes (I hope very soon) this bug.
Best regards
Delio
